As above please!
James
I wanted one of them so I could use the original temp gauge on clocks, but it's going to work out cheaper to buy a complete aftermarket clock
with matched sender, told by Yam dealer sender is about £60
tony
This what you want?
Image deleted by owner
[Edited on 4/9/09 by Lurch88]
Most probably! I don't know for sure what one should look like, but it does seem right. Is it from an R1? If so then I will take it off your
hands
James
Asuming the 4XV is the 98-99 carb model then yes its the right one.
I used it with the original clocks to give temp reading.
£20+postage?
Aye go on then!
u2u being sent...
James
