WTD: fuel pump inertia switch GOT ONE NOW
Humbug - 20/9/09 at 04:25 PM
After reading Jasper's tale of woe, I was thinking *maybe* I ought to have an intertia switch in my fuel pump wiring. I have got a hand-operated fire extinguisher but an intertia switch would be one more way of possibly limiting the impact of a crash... not that I am planning to have any, mind!
So, has anyone got one going spare, or could recommend one? I see a couple on ebay, but I have no idea if they are any good. Also, with "spirited" or track day driving, is there any danger of the switch getting activated unintentionally?
Simon
[Edited on 21.09.2009 by Humbug]
RichardK - 20/9/09 at 04:30 PM
I got one of these, seem to do the trick, think its off a rover linkly
Cheers Rich
big_wasa - 20/9/09 at 04:39 PM
The switch fitted to the Mondeo is easy to install so is the one on the peugeot 306.
Ive just had a look but can not find the spare I had or I would have sent it over.
Your only looking at a quid at a scrap yard plus time an petrol.
BenB - 20/9/09 at 04:43 PM
I haven't installed my one yet (Sierra) but you have to give it a reasonably rapid twonk to set-it off. Don't expect track days would be a problem unless you kept on crashing!
Humbug - 20/9/09 at 05:08 PM
Thanks for the replies. I will look at my local scrappy. If no luck, then £8.99 for the ebay one doesn;t seem bad!
Simon
coozer - 20/9/09 at 05:13 PM
Have a look at the 200/400 old Rover, the switch is up under the dash just behind the radio, should be easy to see in scrappys with the radio whipped out.
I used to pull the plunger up when I was parked in town as an anti theft device.
Humbug - 21/9/09 at 12:26 PM
Got one - my local under the arches mechanic was scrapping an old Mondeo. Nice and easy to get at, too - just behind the passenger footwell trim.
Now I've just got to find a convenient place to mount it in the seven
