13" wheels
jon b - 27/2/10 at 07:57 PM
Hi, looking for 13x8 wheels with 100 pcd, curantly running 15x6.5 with a 38mm off set, what off set would i be looking for on the 13x8 to keep the same outside line? im located mid Devon. Jon
phelpsa - 28/2/10 at 01:29 AM
S2000 midget... were you going round the track at the Retro-Rides gathering?
You'd be looking at a very high offset to keep the same outside line, around ET55 which I doubt you'll find without custom split rims (= ££££). You'd probably be pushing clearance on the inside and compromising steering geometry too.
Thought about some period style arches?
jon b - 28/2/10 at 09:36 AM
Hi yes great day at retrorides, there are arches on it giving room for a lot wider wheel, i've had a 15x8 on, thing i'm little concerned about is clearance of the calipers as it's on MX5 hubs.
Jon
