who makes a exhaust manifold for a bec
Im in the same boat
however im looking for a hayabusa one, it would be much easier to answer if you told us the engine
Mike
fastdan????
Too many variables to be of any use....!
what car, what engine and what price do you have in mind?
mk indy r
2008+ busa engine
no price in mind (it cant be more than a vx220 turbo one)
Caterham
Westfield
MK
Then the zorst manufactuers:
Zorst Manufacturers on google
also keep an eye on ebay, as Busa kit comes up more often than other engine types....
the OP says he's biuilding a race car, so if he wants a money no object race winning exhaust, then i've heard good things about simpson exhausts. if just a road car, then as above, caterham, westfield, MK etc
929 blade and do the 919 manifolds fit eather
Is it front engined or a middy?
If its any sort of one-off I doubt if anyone can make a manifold for it without having the car to work on, unless you could supply very accurate
drawings or good photos of the engine install.
If its a known quantity ie. Megablade. Indyblade, then I would approach the manufacturer.
The exhaust port spacing is the same on 893, 919, 929 and 954, not sure about CBR1000RR. We used our 893 port jig to produce our 929 manifold.
Not sure about the actual manifold shapes being interchangeable.
Andy Bates might be along soon. He'll know.
So what chassis is it?
Geoff.
I'd speak to Martin Keenan, Im sure he would either do it or know someone good todo it
I'd go to Martin Keenan (MK Engineering)
