Im looking for a plastic widget which fits onto this Ford throttle linkage - anything that will allow me to connect a cable in fact ....
Any ideas guys?
[Edited on 18-10-10 by RazMan]
Get a 2a terminal strip (Chocolate block) thread the inner cable through it and back through the strip making a loop, tighten up the screws on the
strip and off you go.
Bob
Refreshingly simple and Locost idea
but I am hoping to find something a bit more permanent. A cable loop will have some slack and will also be at
risk of jumping off when not under tension. Thanks all the same
I'd recommend a spring loaded linkage similar to waht is used on SUs.
here is picture:
http://jaguaretype.files.wordpress.com/2009/08/img_4638.jpg?w=470&h=312
on the left link with a sping loaded collar that as hole in the side. .... unfortunatley you cannot see what I am about to describe.
but by pulling the collar down, the round end piece (spherical in case of SU) fits through the hole and the collar spring back to hold it in place.
no idea what these things are called but I can look in the SU manual if you want.
oh, forgot to say, these are on the end of rods, not cables.
[Edited on 18/10/10 by 02GF74]
Yes, I was looking at one of those (quick release ball joints btw) but it is too chunky and, as you said, made for rods and not cables.
I am tempted to drill out the existing pin and weld in a longer one with a split pin in the end, then make up a little clevis pivot to mate up with
the cable.
This would be quite time consuming and if a plastic widget is available it would be much easier
