Hey Guys
I'm looking for a company that sells stainless exhaust components so I can make my own manifold. Specifically I need a 4:1 collector with either
a 1 3/4" or 2" outlet and anything LESS than 1 1/2" primary's.
Everything I've found so far want to charge me atleast £200 for the component or simply don't stock components which arn't stupidly
sized.
Any help?
-Josh
have you got a flange?
Yup, I got one laser cut locally, saved alot of work and was very accurate
Try OJZ Engineering. They sorted me out with all the bits I needed, including a pair of
pressed collectors with 2" outlets. Pressed collectors do not flow quite as well as merge collectors, but are a fraction of the cost.
Here's a not-very-good pic of my offside headers - you can just about see the OJZ collector.
Originally posted by AdamR
Try OJZ Engineering. They sorted me out with all the bits I needed, including a pair of pressed collectors with 2" outlets. Pressed collectors do not flow quite as well as merge collectors, but are a fraction of the cost.
Second OJZ very helpful guy's, and there stock is monumental. HTH Ray
