Hi, had a look at my lads brakes today and the pad pins are seized in placed, any idea where I can get some more?
I understand that they are £18 from a stealer, would prefer not to have my pants taken down if possible.
Cant really go near them with fire as the piston seal is too close, want to get some replacements before so I know what I'm up against if I have
to resort to drilling them out
Any ideas, cheers.
Rich
you get them as a 'fitting kit' from just about anywhere that sells the pads (ferrodo, brebo....) - used to cost me about £6 a set (a set
has 4 pins and the two anti-rattle spring thingys)
any decent motorfactors or even halfords should have them
I used to try and save them, but its was a real PITA to get them out at all never mind in god enough condition to re-ues them
so in the end I just got new pins every time and used bolt cutters to cut the old ones out - back then I could do a set of front pads on the 106 in
15min - I went through alot of pads! (ask Mango...)
they have a tappered end to them so you can only use a very small punch to get them out and they always seize
you can't really drill them without wrecking the caliper either
as far as I could work out the main reason they don't want to come out is the pads twist a bit and jam them, but also the spring colar thing that
stops them falling out
send us a u2u if your having trouble and I'll give you my number
[Edited on 8/1/2011 by mcerd1]
