Need to get hold of a crank position sensor. Standard ford should work for the Omex ECU
[Edited on 12/4/11 by SeanStone]
I'm sure I have one of the two mounting screw types, not the Zetec type, I'll find it when I get home tonight and post a pic up.
Any good, with plug an about 600mm lead
Looks to be suitable. I presume they all do the same thing?
I used it to bench test my megajolt, and it worked fine, in the car it will need shielded leads, or the existing ones shielding, but its an advantage
having the connector and so much wire to work with.
U2U me if its any good, only looking for £10 posted..
