Evening all,
I need to remake my front wishbones as I've spotted a bend in one of mine. I'd like to make them out of flat sided oval tube. Does anyone
know of any suppliers? I've looked at Ralt, but they only do the aero stuff and apparently it comes at a price.
Thanks in advance.
Chris
MK Sportscars do oval tube for their wishbones
Any oval tube will do, it does not have to be flat sided.
Plenty of stuff about in steel.
I think a search for steel extension stockists will help.
You can get it anywhere!!
http://www.cherinproducts.co.uk/tubes.htm
http://www.applegate.co.uk/all-industry/products/oval-steel-tube-0093234.htm
http://www.preferredtubes.co.uk/
Originally posted by ChrisLeary
Evening all,
I need to remake my front wishbones as I've spotted a bend in one of mine. I'd like to make them out of flat sided oval tube. Does anyone know of any suppliers? I've looked at Ralt, but they only do the aero stuff and apparently it comes at a price.
Thanks in advance.
Chris
Probably because he likes them. I got some from MK when Martin was still there and it works fine.
Evening all,
Thanks in advance.
Chris
The question to ask is why would you want to make your bones out of flat sided oval tube?
ADR do lovely end fittings for their 30 x 15 oval tube. The only issue is that the tube is only 1.5mm wall so it might not be deemed suitable for an arm that is supporting a lover shock mount and the force that comes with that.
Check https://randallmotorsport.ssl-01.com/product_info.php?cPath=71&products_id=545
