Can anyone help me with the folowing parts for my Sylva Striker re-build.
1300 sump (not sure if the 1600 is the same)
Head Gasket
Distributor
Facet Fuel Pump
Spark Plugs
Distributor
Water Pump
Chris
[Edited on 10/1/12 by cfc999]
What about a complete 1700 engine/Type 9 gearbox with twin Weber 40s?
I'm hoping to have mine out of the car this weekend, but I'm
probably keeping the alternator. The Type 9 isn't definitely for sale yet because I want to check the new gearbox fits first.
Probably not what you're after at all, but it's worth a go.
Thanks for the offer but just after the parts listed at the mo.
Chris
I've got one of the square Facet pumps sat on a shelf doing nothing - just the pump though I think, no unions etc (I'll check if you're interested) Didn't get used for long as I recall but it worked fine......... dunno £20 posted?
1300 sump is smaller than 1600. The smaller stop catches the crank or something when fitted to the larger engine. No proof but a guess says it would be ok your way round but i'd check the oil pickup pipe isn't sitting in thin air.
Hi
I've got 1300 sump and distributor (other 1300 x flow parts as well in case your list gets longer).
I'll U2U with details.
Colin
Originally posted by emidas
Hi
Colin
1300 sump is definately shorter and will not fit a 1600 without a beasting with a hammer.
I have a dizyy in Birmingham.
Now sorted with sump, pick up pipe and water pump. Thanks for all your offers.
Still on the look out for a desent dizzy. I'm runnung a pair of 40's so not sure if a standard one is up to the job. Also am I right in
thinking I need a angled dizzy cap.
