I need to move my alternator from the nearside to the offside under the inlet plenum.
This time it will be a small Micra job, is there a bracket available? or, can anyone post some pics so I can see if I can be bothered to fab one
up?
Ta,
My Denso alternator is on the inlet side.
I made a really simple bracket out of a piece of angle steel roughly 25x25mm with a bit of 4mm plate welded on the end to give a flat surface for the
alternator to bolt to.
This was bolted to two of the holes in the block
Stu
There's a thread about it HERE
Come and have a butchers at mine Steve, its under
the plenum and consists of three bits of 5mm plate
and a piece of 2mm to act as a spacer.
I even have a cardboard template that you can have
and the alternator is the same as mine as well.
