metal water pipe wanted
AndyW - 19/4/12 at 09:53 PM
hi all
I am ready to plumb in the engine now so I need some metal pipe (i think a couple of outlets on it). Anyone know who can make some up for me? Im using the standard thermo housing on a 2.0 blacktop. No heater but I am using a header tank mounted on the scittle panel
[Edited on 19/4/12 by AndyW]
zetec - 19/4/12 at 10:28 PM
You can get plenty of different sections of ali tube with take offs ready made from the motorsport trade. Dont forget your local plumbers merchants, find a decent one and I bet they will have everything you need for a fraction of the cost of custom made parts. I've had copper fittings fitted in my fuel and cooling system for 9 years now and not a single issue.
MakeEverything - 19/4/12 at 10:46 PM
Andy, Let me know what you need. I might have the materials already, and be able to make it up for you. All i need to get is some more welding gas as my fire extinguisher er i mean CO2 cylinder has expired!
russbost - 20/4/12 at 08:51 AM
If this is the Zetec coolant pipe I do one in 32mm beaded, 2 x 19mm outlets equally spaced £32 + £3.95 P & P
HowardB - 20/4/12 at 09:19 AM
watching with interest as I have just got to the same stage on the Fury, water rail and pipe work is the next job,... onward and upward
