I am after 16 wheelnuts, 12x1.5mm (ie std ford) but the ones for alloys with the spinning washer, and open, (that is you can use a long stud that goes
right through them)
Think they were used on alloys that had a trim covering the nuts.
Before I trawl fleabay, anybody got a set laying about?
Clive
[Edited on 15/8/12 by cliftyhanger]
I think I've got a few of them kicking around, or at least I did have some time ago but we've moved since I last saw them. I'll have a
look in the garage later and let you know.
John
I also needed some of these, and went down my local wheel and tyre place, and got all i needed from a bucket,
cost me a fiver, take a bolt the same thread as yours, makes life easier
steve
John, if you find a set, let me know.
Steve, was that a specialist place or a thickfit type of outlet?
I got mine from here after I had aquired a set of 80's allycats, they needed the depth of the mounting
hole to ensure they supplied the right nuts.
[Edited on 15/8/12 by Westy1994]
Lethal alloys a fancy chavvy type of wheel place is at my local shops,
personly i would use them, but i needed a handfull of nuts
