3 Point Seatbelts for JC Locust
markie76 - 1/9/12 at 11:57 PM
Hi Guys,
I'm almost ready to MOT my recently acquired JC Locust Wide Body Sports but am missing seat belts.
The original donor was a Sierra (1982 I believe) and it had 3 point belts fitted.
These were removed to be swapped for a 4 point harness - which didn't get fitted.
So, the original buckles (recepticles) are still fitted in the car.
The top mounting hole on the roll bar mounting frame is empty.
The bottom 'belt' mounting hole is empty.
I need to fill the gaps (driver & passenger) with an automatic or static 3 point belt.
I will need the belts and recepticles
OR
Just belts if you have ones which will be compatible with 'assuming' circa 1982 Sierra/Ford recepticles.
Thanks,
Mark.
[Edited on 1/9/12 by markie76]
markie76 - 20/9/12 at 01:56 PM
Thank you to loggyboy for sierra seatbelts.
Now fitted and car MOT'd - following replacement of a steering rack gaiter and massaging the O/S front caliper from its slumber causing an imbalance. Not bad for a car thats been off the road for a number of years.
NOW, just need to sort out overheating and investigate the occassional blue smoke and white puffs on acceleration
kipper - 20/9/12 at 04:15 PM
I had a locust a few years ago,I don't your's is my old one?
It was white with a blue interior and had.......... WET in the reg No.
Regards Denis.
loggyboy - 20/9/12 at 04:28 PM
Regards Denis.
I think his is red http://locostbuilders.co.uk/viewthread.php?tid=174606
markie76 - 20/9/12 at 04:53 PM
Thats right mine is bright red and has ENN in the reg with black interior. Passed its MOT today and just have to resolve some overheating and I'm hitting the road!!!
Will post pics to show it off shortly
[Edited on 20/9/12 by markie76]
