My local steel stockholder ( 100 yards away ) takes my order list, promises to phone with a costing, but never does.
I need to fabricate replacement engine mounts so I need the following:
2 off 8.0cm x 6.5 cm 3.0mm thick plates
2 off 9.5 cm x 8.5 cm 5.0mm thick plates
1 off 1.0 m 3.0 or 4.0 cm square box section, say 3mm wall min.
Can you supply ? Will pick up anywhere within 1 hour from North London or pay postage.
edit to correct minor mistake - only out by a factor of 10
[Edited on 3/9/12 by Macbeast]
For small amounts like that I've found ebay prety good, can normally get exactly what you want (or damn close) for not a massive premium.
Or go to the local scrappers and find something you can dice up with a slitting disk..... £10
Originally posted by Macbeast
1 off 1.0 m 3.0 or 4.0 mm square box section, say 3mm wall min.
Metal Supermarkets?
Not cheap but fairly close:
Link
That can't be right? 3mm wall thickness would be at least 6mm square surely?
I'll guess it's 30 or 40mm
It is - sorry
3.0 cm 0r 4.0 cm square
Another option is to go into said steel stockests, have them rummage in there scrap bin, and then give them a tenner. In that sort of quanity they are
not going to be interested in pricing it up properly I wouldnt have thought, unless there not very busy.
Daniel
That's what I was hoping
At least, if I go to Park Royal ( thanks Ben + Stu) I can get a coffee at the Ace Cafe on the way back
Got my engine mount materials from these guys
http://myworld.ebay.co.uk/steel2go/?_trksid=p4340.l2559
Great service, gave multiple discounts on postage, then when they weighed it up and sent it off, they even refunded me the extra £1 something they had
overcharged!
For that amount of plate, try doing a google search for a local steel fabricator. Thats what I did for my engine mounts and I picked up more than I needed from their off cuts bin for a contribution to their charity collection box. The one I used was in Derby, so not much use to you though.
Yeah for small lots a stockholder wont want to know about pricing up, going in on a Saturday morning is the way to go. I made a stainless exhaust for my van recently, had the pipe but needed metal for the flange at the front & the hanger brackets, so 1.5m of 12mm rod & 75x100mm 8mm plate. Lad has a quick look about & says gizza fiver mate!
Very pleased to say Acton Metalsupermarkets supplied exactly what I wanted. Plates ready cut to size.
£ 14.00 for the two sides - not at all expensive. In and out in 15 mins
