Im after a ready made omex 600 loom for a zetec blacktop, complete with all the plugs, if possible
I guess ringing Omex isn't what you had in mind?
you got that right
I think you are in for a long wait then. Just in case here are the prices from Omex
OMEM1419 Road Spec Basic Loom (600 system) PVC tubing and harness tape, ready built harness for basic NA engines £174.00
OMEM1419A Road Spec Basic Loom with MAP (600 system) As above but with MAP connection for boosted engines £186.00
OMEM1519 Race Spec Basic Loom (600 system) Raychem sleeved, ready built harness for basic NA engines £294.00
OMEM1519A Race Spec Basic Loom with MAP(600 system) As above but with MAP connection for boosted engines £312.00
OMEM1520 Race Spec Full Loom (600 system) As above but with MAP connection and auxiliary connections £354.00
OMEM1502 Semi Assembled Wiring Loom (600 system) ECU connector with 3m trailing colour coded cables £60.00
OMEM1504 Auxiliary Wiring Pack for OMEM1502 (600 system) Add-on pack to OMEM1502 for auxiliary functions £12.00
I guess you would need the OMEM1419 if you want plugs as well at £174 or the OMEM1502 at £60 if you want to DIY with the plugs.
[Edited on 24/12/12 by jeffw]
still in need of one
