Striker Propshaft
matty h - 5/2/13 at 10:29 PM
I am looking for a striker propshaft from sierra type 9 bo to escort english diff.
Anyone help before I ring around the propshaft specialist to repair mine.
thanks Matty
daniel mason - 5/2/13 at 10:40 PM
does the english axle have same stud pattern as 7" ford diffs?
if so i have my caterham one at home which is no use to me as im fitting hayabusa motor!
i can measure it if you want? sure my car is slightly longer than a striker but the engine was as far back in the chassis as possible so might be very very close!
owelly - 5/2/13 at 10:46 PM
I can strongly recommend Dunning & Fairbank for prop repair/build.
Tell them Owelly from PPC sent you and you may get a couple of quid knocked-off!
http://www.dandfltd.co.uk/
matty h - 6/2/13 at 11:34 AM
Not sure on the hole centres for the prop are the same, I know they are both four bolt but the pcd maybe different total lenght is 680mm end to end and bolt flange is 90mm pcd on the one I have.
Dunning and fairbank are my next port of call just seen if anyone has one first.
thanks Matty
