As it says I could do with a good S2000 radiator.
I’ve got my old smashed radiator as a template and can indeed make one fit my Kitten project so that’s what I’m after.
Have you chaps got any going for beer tokens?
Cheers.
not too sure what i did with mine. ill look through garage. i bought a pro alloy race one to fit my mnr nose cone
That would be a good result if you have it still.
cant remember wich one was wrecked. coolant rad or A/C rad. one of them was knackered!
alternatively most rads will do the job in such a light car and wiring can be adapted to suit! are you putting a fan overide switch in or just using
the thermostat and honda ecu control?
Ill put an over ride switch on if I have issues with cooling, but don’t see why I should if I get an s2000 rad as they are rather massive in area and single core with twin fans. I have the fans although one is a bit smashed, but still works. Cheers.
just thought youd want a lighter setup if competing. should pick one up cheap
Good point, I want it on the road for March (no chance but) hows yours coming on. Let me know as soon as you can about rad because I will get one from flea bay otherwise. Cheers
mines expensive (again) and slow (again) and might have to sell in next few weeks as ive just bid on another house!
Got one sorted thanks.
