coil spring tester
gavin174 - 10/3/13 at 12:06 AM
evening all..
does anyone close to Harlow/Chelmsford or Charlton have access to a coil spring tester..
i have a few 1.9" coil springs of different lengths,
but i have no idea of the poundage..
cheers Gavin
Carbonman - 10/3/13 at 06:18 AM
The poundage/rate is normally stamped/engraved on the ends where they have been ground flat.
f750sgr - 10/3/13 at 10:54 AM
Drill press and a steel rule will give you a rough idea. Locost style
gavin174 - 10/3/13 at 10:58 AM
please can you expand on this a bit more
cheers Gavin
matt_gsxr - 10/3/13 at 12:48 PM
Set of scales for measuring the force, a way of compressing the spring, and a way of measuring the change in distance.
Drill press sounds like a nice way to compress the spring in safety.
I've not done it myself but as long as you don't overdo the forces it should be pretty easy
