I have come to the conclusion that my fabrication skills are not up to the job, and I need two brackets making the will support my headlights and
indicators. I have produced a very basic 3d CAD drawing of what I need making (well the right hand one anyway...) and wondered if any of the more
gifted welders would be willing to have a look and maybe provide a price for their time and materials in making me a pair?
I have provided a shot from CAD of what I am after, though the cyan piece should be a triangular gusset, I've never used CAD before and so this
was the best I could do...
I am a bit far away to help, just a hint for you, thickness and material type is a good start, some dimensions thereafter
Hi not close enough to help on the making but I put a quick drawing together of what I think your looking for so mark up with dims and then someone
may be able to help.
[img]
BRACKET
[/img]
cheers Pete
Sorry of cause, longest edge on red piece is 12.5cm, longest edge on blue piece is 10.5 cm, short edge is 8cm.
Material and thickness I'm not too bothered, and so cost and strength dependent I suppose. I would need guidance from whoever makes it. I've
knocked up the design based in what I remember the original being like, which also had the bracket for the original clam shell wings on, unfortunately
I no longer have them and of cause measurements I've taken of where they need to fit.
Originally posted by watsonpj
Hi not close enough to help on the making but I put a quick drawing together of what I think your looking for so mark up with dims and then someone may be able to help.
[img]
BRACKET [/img]
cheers Pete
Measurements as below.
like this then
[img]
bracket2
[/img]
just need to add the thickness I've gone with 2mm
good luck getting it made
Pete
Exactly that. Thanks
Local rhocar member has offered to make them if I supply material
I have enough 1.6mm steel already, would this be strong enough or should I stop being tight and buy some 2mm? I have room to add another gusset to
the underside of top section if needed.
