Braided Fuel Hose (500/600mm)
spdpug98 - 27/5/13 at 01:35 PM
Does anyone have a 500/600mm piece of braided fuel hose, typically I know I have some in garage somewhere, but only found a 300mm piece up to now......
sdh2903 - 27/5/13 at 04:57 PM
Is it the low pressure cotton braided stuff your after?
If so I've got some 8mm you can have if you cover the postage.
spdpug98 - 27/5/13 at 06:20 PM
Thanks, I appreciate the offer but its stainless high pressure hose I need (I think its high pressure as fuel injected)
[Edited on 27/5/13 by spdpug98]
scudderfish - 27/5/13 at 07:49 PM
You don't need braided on the HP side, regular injection hose will do fine and any damage will not be hidden under the braid. I replaced the two lengths of braided pipe after I found this feeding my injectors.
