Hi all,
I am after an off-cut of either 3" mild steel round bar or 3"O/D thick wall tube (inside dia no larger than 60mm)
Minimum length 58mm.
Tilly
[Edited on 1/6/13 by tilly819]
I think you will have to have a piece of solid bar bored out.
That's a 15mm wall you need something machined, what's its for that nigh on bullet proof!
Im doing the machining myself, that is the blank size, I am quite happy to bore out from solid.
8mm wall
Tilly
