As stated really, I am in need of a gear selector arm--- the one that is splined and fits directly to the selector shaft of the box, lost mine in
moving garages,
The engine is a suzuki TL1000, but im fairly sure the Hayabusa one fits.
Ian
Apparently all Suzuki splined ones are the same. Loads on ebay.
I was able to obtain (via a now redundant source) the actual steel splined boss that fitted on the gearchange shaft. I could then weld any lever
arrangement to it. The place I bought these from went to the wall, suddenly, but someone out there must know the source.
I'd like another couple of the bosses to fit some other installations on the table at the moment. If it helps, the Westfield Megabusa lever is
built around the steel boss, so you might (like me) acquire one of these and cut the lever bit off. If you can get out of Westfield where they get the
boss from..... I get the usual 'made off site' answer.
Anyway, yep, the Suzuki shaft has coarse splines, much coarser than it's rivals. Nothing else fits (that I can find anyway). All the same,
GSXR600-1300, etc.
