Hi All, new to this and after buying an un-finished kit I have realised i require the following:
gauges to replace original (hideous) standard sierra clocks compatible with type 9 gearbox
4 into 1 manifold to suit 2.0 pinto
Vicki Green or similar wiring loom (this is probably the first thing i require. original sierra loom has been butchered!
all would need to be posted to south Wales unless close enough to collect.
Let me know if you have anything suitable.
Thanks in advance
