Hi all,
May as well ask, just in case anyone has the following that they want to get rid of and hasn't decided to put up a for sale thread!
I'm after a set of ETB gauges. Preferably black faced with white dials - but I'd consider alternatives!
80mm electronic speedo
80mm tachometer
52mm fuel level
52mm water temperature
I'm specifying ETB because they are the one company I've found who 1) state their bezel sizes, and 2) have bezel sizes that will fit in my
dash!
I'm open to other options, so long as the speedo/tacho have a maximum bezel outer diameter of 85mm and the fuel/water gauges have a maximum bezel
outer diameter of 56.5mm!
Cheers!
Garry
Linky
The speedo and tacho are obviously no good to you, but I'm open to offers on the 52mm gauges.
Thanks scootz,
I'll keep it in mind if someone else has a white speedo/tacho and no fuel/temp
No probs.
