Hi guys, im after a set of duratec crank bolts, second hand is ok so long as they haven't been used more than once.
Many thanks
Adam
I've got a set of ARP mains studs which I fitted, then removed because they got in the way of the raceline sump and baffle plate arrangement as
they are studs and nuts rather than bolts. They haven't been in a running engine and are essentially new.
£116 from Burton Power
Linkage
If you want them I'll let them go for £65 (plus postage if you are not picking them up)
[Edited on 5/9/14 by Mr C]
If you can give me a little time then SOLD!
thanks
