Has anyone got an MK indy bonnet not required.
I would prefer an uncut one, as new. In Yellow, but may also consider black
I have a yellow bonnet from a Mac1 which I believe will fit. I now have one off a MK Indy fitted to my Mac1 so don't see why it wouldn't go on yours. It does have a cut out where the exhaust went through though. Has a carbon fibre effect on the scoop.
the cut out would be on the correct side if your exhaust is to come through as I had a pinto when I was using this bonnet.
Hi bluePhil
Have sent you a U2U message.
