Hi all
does anyone know where you can get a connector which pushes onto the oil seneder or temp senders.
I cant find anyone that sells them.
Does anyone have any on an old loom possibly?
Its on a ford 1600 crossflow.
I think the pinto senders are the same style and probaly others from that era. 70's 80's
[Edited on 5/4/16 by Gemini]
which engine?
Oil temp? Don't you need a sensor in the sump below the oil line??
hi
i am looking dor the small plug that pushes on to the end of one of these for the electrical wire.
Intermotor Oil Pressure Switch - 50590 - For FORD Push Rod KENT engine
Search for "bullet terminal" should find what you want
