As title says I'm looking for the long bolt that goes through the top mountings on an 898 blade engine
A local man, I just cut up a couple of old bolts and welded into one, I expect you could also use a length of studding from B&Q
I was hoping to get a bolt, I've got studding at work and could weld some bolts together but trying to do it right 😊
