Putting a Caterham screen on - see if i like it - in need of a pair of screen brackets.
Don't fancy eBay stuff
U2U .. PayPal waiting..
cheers ..
[Edited on 26/10/16 by johnemms]
I bought a sheet of alloy from ebay and made some Mate.
Turned out pretty well
Go on, give it a try
Probably would do if I had a template ...
Depending who made / what make the scuttle is will determine what the radius is.
If the glass is cut for another car, you say that you want to fit a Caterham screen, then the width of the screen will vary.
The side edge on some slopes in while others have a screen that's the same width at the top as the bottom.
If you have a wider scuttle and a narrow screen, or the other way round, this will effect the shape of the screen support.
So take note of Mash. If you want it to fit, make it to fit. It's the only way.
Originally posted by johnemms
Probably would do if I had a template ...![]()
Cheers Dick for the pdf file
Its a Caterham S3 - 90cm at bottom - onto an MK Scuttle..
Should be okay..
Ive got a complete screen and brackets which I made to fit a Westfield that are available. The brackets are the same design as a Caterham but the
screen is a narrow body Westfield one
U2U me if of interest
