Hi,
I'm after a 20-25mm type 9 spacer to go between my Bellhousing and face of Type9 fitting box.
Believe they are mainly used on caterham or fitting V6 box to pinto due to longer input shaft.
Anyway, if anyone has one under their bench I'll buy it.
[Edited on 18/11/16 by Benzo]
If you're having trouble getting one I can get one made for you. That is if you can provide a sketch or a sample.
Thank you for the offer
i have the dimensions somewhere
