As the title says a set of cream Bosch injectors. Or if not where is the best place to purchase?
Regards, Jon
Best bet is a complete and new inlet manifold from a crate engine.
New, genuine, cheap.
They come up regularly but I can’t see one today on eBay.
These are to go in a set of Jenvey throttle bodies. But thanks for the reply.
Yes often you buy a tb/ecu package they often come pre mapped and set up for the standard blacktop cream injectors. I know the omex package I am
looking at does.
Bosch 988f-eb and are quoted as 209cc/m @ 3bar
A complete inlet from a crate Zetec sells for as little as £20 and the fuel rail, injector loom iacv are all desirable on there own.
http://www.retro-ford.co.uk/shop/content/genuine-ford-standard-zetec-black-top-injectors-set-4-z079-180-bhp
Or maybe either Dunnell or Raceline will sell you some from a crate motor they upgrade at 5hey will not use the for theatre pre assembled engines
Not sure on your spec' or what your planning but Iirc these run out of duration at about 210bhp and SAAB Reds work better after that
