Hi guys
This is a long shot I know.
But does anyone out there have a old set of twin SU carbs 1.1/2"
(I am looking for the choke connecting rod linkage that joins the (2) chokes together)
Any one ????????????
Thanks in advance
Might be able to get one from an MG specialist? Nice to see your still about Bill, do you still have the Luego?
Try Andy Jennings MG Spares for secondhand bits: https://www.mg-cars.org.uk/andyjennings/
Or Mechspec for secondhand MGB bits: http://www.mechspec.co.uk
If not MGB Hive: https://mgbhive.co.uk/product-category/mgb/
Or Rimmer Bros: https://rimmerbros.com/Item--i-GRID019709 (also will have SU stuff for Triumph etc)
I should have asked what engine are these carbs on? As there are twin 11/2 inch SUs on many Triumph, MG, Austin etc vehicles
Burlen Fuel systems supplies many SU parts: http://sucarb.co.uk/linkage-parts.html
Mike
[Edited on 20/7/19 by Mike Wood]
The bar itself is just 5/16" (8mm will work but needs fettling at the ends)
But if you need the clamps it could mean a specialist. Burlen being the people to speak to.
Burlen will have all you heed
http://sucarb.co.uk/linkage-parts/hs-linkage-kits.html
Cheers Guys
Ordered from Burlens
Hi Rusty
Yes I still have the Luego but not used it much over the last couple of years,
Bill
