I’m looking to upgrade my Luego Velocity this winter by removing the pinto and fitting 4age 20v. I’m looking for parts to help with this. I have
listed below what I need
Exhaust system
Ecu/ management
Wiring loom
Does anyone have any parts lying around or can point me in the right direction to get them.
not sure if this helps much but the 16 and 20 valve exhaust systems are very similar (except for one mounting hole being moved by a few mm).
I am planning to make my own using a flange plate from Danst engineering.
I have a 16v exhaust manifold spare left over from my westfield conversion plus a 16v exhaust flange both in stainless.
Richwill, If you don't buy Dave's manifold, I might be interested
What are you doing for the gearbox, bellhousing and clutch?
Dave I would be interested in the manifold and plate. Please message me about price etc
Jon
I have a T9 gearbox with correct bell housing and clutch
What do either of you use for the spigot bearing?
I have a couple of spare bearings if you need one
