I've managed to bust my indicator stalk/hazard switch assembly.
I have the MK1 Sierra variant with the square hazard switch and just the indicators and headlights on the stalk (ie no horn).
Does anyone have one going spare?
Is this what you're looking for? :-
I have several Indicator/headlight stalks for Sierra that I'm getting rid of.
Tony
Tony,
That's pretty close to what I'm after. My picture isn't the best but this is what mine looks like:
The only obvious difference I can see is the hazard button arrangement - have you got anything with a square hazard button?
Graham
The Ford part number is on the switch so it should be easy to identify the correct one . Fitting the wrong one may well cause problems
Good point.
I've got both a mechanical and an electrical gremlin going on with the switch...maybe I'll spot the issue this time.
I'm going to take it off this morning (again!) and strip/rebuild it once more....if it still doesn't work I'll take some proper pics
this time and make a note of the part number.
Graham
The number on the one in the pic I posted is :- 87BG 13B 302 AA
I have 1 other indicator stalk that has a square hazard - but has the horn push too. It's number is :- 83BG 13B 302 BA
If you need I can get pics of the connection pins on the back.
Happily am now sorted, thanks for all responses.
Graham
Sorry to jump on this, but now Graham is sorted.
I'm also after the same Mk1 Hazard switch unit. Mine is even earlier with more square stalks.
The hazzard has started to go dodgy and takes a few goes to latch off, so before it goes completely.
Anyone got a spare?
Best one i could find win my gallery
[Edited on 30/8/20 by ReMan]
Try a squirt of contact cleaner or WD40
Yes cheeers. Done wd40, ipa, ptfe.
Time for a new one, or at least one to hand before `i crack it open
Bump 2
Uploading pics not working for me at the moment
http://www.plusnine.co.uk/wp-content/uploads/2020/09/fukfuk.jpg
Anyone got one?
Love the name of the jpg lol.
What's the serial number on your stalk?
I have 2 Indicators. The rear of 1 of them looks identical to your pin layout. The other is totally different :-
The code I was meaning though is the one on the front flasher unit part. On this one it reads 87BG 13B 302 AA. I think this is the important code
isn't it? :-
Tony
Cheers.
Do you have the red hazzard light cover-push to go with it?
I'm sure that mine is the same as GrahamC's pic above and it does not have the white plastic flange around the base of the hazzard switch.
Having said that I wonder that if the connections are the same, I can make a hybrid Mk 1.5 from it.
I also see your only just down the road from me
Sorry bout the delay - had a busy morning.
Ok - I have both the caps (the round one is slightly damaged and doesn't stay on properly) - but the bases don't look interchangeable in any
way unfortuately.
Yeah Burbage is not far from here (I'm at CV21 1JE) - you're more than welcome to come have a look/try?
Tony
Hi
Likewise busy day on the other car still only half done and an MOT on Monday!
Anyway, I reckon that the one on the left is correct for me, there's just a slight detail on the white plastic thats different, but of course,
its possible mines been butchered.
The code is the same
Ive put a few more pics here as I still cant get the upload to work
my pics
So assuming your selling I'd like to fly down and get it?
Do you want to U2U me.
[Edited on 5/9/20 by ReMan]
Yeah no probs at all - U2U'd.
Tony
Replied
