I am looking for this Ford throttle cable, it has 92060 on it and my local German Ford garage think it may have had the part No 6605418.
Here are a couple more pics which may help.
http://www.beepworld.de/memberdateien/members18/claudiasbilder/carbend1a.jpg
http://www.beepworld.de/memberdateien/members18/claudiasbilder/carbenda.jpg
http://www.beepworld.de/memberdateien/members18/claudiasbilder/pedalenda.jpg
would you not be just as well (seeing as you're getting desperate
) to braze or solder a new nipple on?
I have asked for advice at my local motor bike shop and pedal bike shop, both think it is not a good idea (apart from a short term fix to get you home) to fix the cable, I have very little fettling time left spare before going to Le Mans in a few weeks, so I would like to use a replacement that I know works and will last a few years. It takes me about ten hours driving to get to Le Mans so I would like it to be fairly reliable.
my suggestion then, would be ebay.
usually (at least, on ebay uk) there's a good deal of throttle cables.
There used to be a company called Speedy Cables, I think they are something to do with GreenGauges ? They would make a cable to your pattern/design fairly quickly. They serviced and recalibrated a speedo a few years ago it was returned in about 2 days from posting. Failing that it may be worth checking out Classic Ford magazine small ads?
