Long shot - but after Alfa 105 series engine and box .
Escort MK2 rear axle - hand brake lever - the little bit of metal that acts on the shoes.
do you meen the addjusting arm i just replaced mine only paid 13 quid deliverd if you need it i will find no for you
I have a 105 gearbox from an Alfa Spider
I bought it from an Alfa breaker last year but never used it. I was told it came from a car with 46,000 miles and was in perfect working order. I was
going to use it for a project but ended up taking a different rout, Alfa engine Ford gearbox.
So its sitting in the box they sent it in.
The bit that sticks out of the backplate through the impossible to find rubberboots.
hello i got my arms from gs escorts there no is01514228333
Many thanks on all points guys - will give them a call.
I have attached pic of the gearbox, this is from a 2.0l spider.
Not sure if a 1300 is the same bellhousing.
Alfa 105 box
Hope this helps.
Wasn't sure how to attach pics in a U2U.
[img][/img]
