Hi all
its mot time for my daily runner and one of the metal clips on the rubber boot on the drive shaft has broken. i did a temporary fix with a couple of
cable ties, but it leaking again, and could do with a proper metal clip/strap.
does anyone know where i can get one from.
also i take it will fail an mot on a leaking rubber boot on the drive shaft
cheers
Ian
cable ties are ok for mot time,make sure the surfaces are clean or they will slip off again
Originally posted by jeeby_man
Hi all
its mot time for my daily runner and one of the metal clips on the rubber boot on the drive shaft has broken. i did a temporary fix with a couple of cable ties, but it leaking again, and could do with a proper metal clip/strap.
cheers
Ian
Most decent motorfactors sell the metal cable ties for this purpose.
Paul.
i usd the old trick of using wire to secure the rubber boot in the groove, and then put some cable ties ontop to make sure
took it for its mot today and it passed. hooray!!!
thanks for the help guys
cheers
Ian
