I am in the middle of my EFI conversion and have not yet got hold of an inertia switch. There are a few on ebay but they do not have the connector.
Has anyone got a spare one knocking around with connector?
Thanks,
Chris
i got a spare one for beer tokens
Are you fitting one just in case of an impact or is it necessary for the EFi you're using????
They are not a requirement, but I have fitted one.
I don't like the idea of fuel spraying everywhere if I do have an accident
Ketchup - U2U sent
BenB - What nitram said! It also easy access under the bonnet to turn the pump off if I spray myself with petrol like I did yesterday when I had my
pressure regulator in the wrong way round!
Ta,
Chris
I've got one off a Rover with a tidy wiring diagram. Is that OK?
Originally posted by chriscook
It also easy access under the bonnet to turn the pump off if I spray myself with petrol like I did yesterday when I had my pressure regulator in the wrong way round!
It was that experience that made meant i was checking my new plumbing outside at the weekend with fire extinguisher at the ready....
Ketchup,
It arrived today - thanks very much for your generosity.
Chris
