Author: Subject: Tow bar and Electrics for SEAT Altea 1.6
craig1410
posted on 29/4/09 at 06:20 PM Reply With Quote
Hi,
Anyone know where I can get a tow bar and 7 pin electric kit for a SEAT Altea at a decent price? I can get the mechanicals from Halfords easy enough but the electrics are horrendously expensive as it is multiplex wiring apparently.
Can anyone explain what the deal is with multiplex wiring? I made my own wiring loom for my Locost so I'd like to think I could build a relay insulated loom for the tow bar. Any advice welcome.
Thanks guys,
Craig.
ps. You can really help me out here as my wife is nagging big time for me to fit a tow bar so she can transport the kids' bikes more easily. We already have a Thule tow bar fitting bike rack you see but can no longer use it since we got rid of our previous car.
dinosaurjuice
posted on 29/4/09 at 06:25 PM Reply With Quote
i think this is what you need.
craig1410
posted on 29/4/09 at 07:15 PM Reply With Quote
Hmm, looks promising. I actually used to work with CAN bus protocols when I designed engine management systems at Lucas Automotive Electronics back in the mid 90's.
Not much info shown on that site - what makes you think this is what the Altea needs if you don't mind me asking? I certainly don't mind spending £22.75 on the CAN relay and then making my own loom if that's what is required.
Any further info most welcome.
Thanks,
Craig.
Edit: I see the same website has a "Dedicated Wiring" loom for the Altea for £115.50 which looks to be pretty much plug 'n' go. This is certainly cheaper than the £200 odd quid which Halfords quoted me and might be worth getting. By the time I add up the cost of the connectors and the CAN relay and wire, it's going to be over £50 anyway and will probably take me 4 or 5 hours to put it together.
[Edited on 29/4/2009 by craig1410]
Bigheppy
posted on 29/4/09 at 09:54 PM Reply With Quote
I dont know how it all works but when I bought my altea I had a tow bar fitted by seat as at that time no one else was manufacturing one. I was told that the ecu would reject any wiring not done correctly. This statement was backed up by the fact that the reversing light bulb cannot be changed for a larger wattage bulb [hardly illuminates] as the ecu sees this as a fault and displays a light out warning symbol. Also the rear side lights and brake lights use the same 21w bulb, presumably low volts for the side light then full 12v for the brake lights.
