DavidW
| posted on 3/5/09 at 09:06 PM |
Denso Alternator to Zetec Pulley and Mount
Having bought one of these Denso
(Charade?) alternators I'm looking for a multi vee zetec type pulley to fit the 15mm shaft.
A bit of a long shot, but I'm also after a mounting bracket before I risk purchasing the tiger one.
Beer tokens waiting along with a growing collection of useless alternator parts....
Many thanks!
big_wasa
| posted on 3/5/09 at 09:29 PM |
Bracket is easy to make. Did this one yesterday. A bit of 5mm plate. The holes are 50mm apart and the back hole is 5mm lower than the front.
The Four track has a multi v pulley but its not as wide as the zetec pulley. Its also tappered instead of a key way so I cant just turn a sleeve to
put the zetec pulley on.
[Edited on 3/5/09 by big_wasa]
DavidW
| posted on 3/5/09 at 09:34 PM |
Looks like you have welding gear?
Unfortunately I don't so really struggle with things like this.
big_wasa
| posted on 3/5/09 at 09:57 PM |
How much is the tiger one ?
any lincs for pics ?
big_wasa
| posted on 3/5/09 at 10:41 PM |
This look like the pulley you want but I would ask the dimensions before buying.
Danozeman
| posted on 4/5/09 at 08:36 AM |
Mine is a pulley off a 1.8d ford alternater. My local auto electrics place sorted me with a sleeve to fit it on the charade alt for nowt.
There is a shaft special sleeve to go i think lucas to bosch alts which is what i got.
Didnt raceline or somewhere do a bracket for 20 quid?
Dan
SeaBass
| posted on 4/5/09 at 09:40 AM |
Wasa... I'd weld a triangular brace across that bracket at the bottom. The weld is right on the joint where it will be flexing. Over time it nay
crack and the alternator will drop.
JC
whitestu
| posted on 4/5/09 at 09:49 AM |
I went to the local auto electric place and they found me a grooved pulley to fit the Zetec - it's a bit narrower than the Zetec pulley, but I
just bought a suitable belt to fit it.
Stu
DavidW
| posted on 4/5/09 at 11:13 AM |
Dan
Which auto electrics place did you use?
Will have a look at raceline. Cheapest I've seen is tiger for about £33 which just seems wrong.
Thanks!
big_wasa
| posted on 4/5/09 at 03:49 PM |
Yep needs bracing as it over hangs the block a fare bit.
I would also like to know where you can get a sleeve for the pulley. A look on google didnt show much ?
cheers
