Author: Subject: Radiator
jeffw
posted on 15/6/09 at 07:38 PM Reply With Quote
Radiator
In a fit of stupidity I have just had the jack slip off the front rail of the car and put an interesting large U in the rad.
It measures 490mm x 330mm (or at least did measure) with top and bottom entry and exit with a bleed valve on the top. It was attached to the car via a right angle plate each side with 4 bolts. The car is a Phoenix.
Anyone know where I can get a replacement ?
prawnabie
posted on 15/6/09 at 07:39 PM Reply With Quote
If its the usualy polo rad, i have a new one you can have for 20 + postage
blakep82
posted on 15/6/09 at 07:41 PM Reply With Quote
have you got any photos? as above, most likely a polo one, but just incase its not, someone might regonise it
________________________
jeffw
posted on 15/6/09 at 07:50 PM Reply With Quote
prawnabie
posted on 15/6/09 at 07:52 PM Reply With Quote
Gutted!!
omega0684
posted on 15/6/09 at 07:53 PM Reply With Quote
Pooh Sticks !!!
jeffw
posted on 15/6/09 at 07:58 PM Reply With Quote
Is it a Polo rad then ?
gavin174
posted on 15/6/09 at 08:10 PM Reply With Quote
"if its the usualy polo rad, i have a new one you can have for 20 + postage"
if jeff doesnt want it could do with a polo rad
cheers gavin
big_wasa
No that looks custom built
jeffw
posted on 15/6/09 at 08:11 PM Reply With Quote
crap.....
prawnabie
Speak to clairetoo, she has just fitted a rad into her fury.
Shaun
adithorp
posted on 15/6/09 at 08:13 PM Reply With Quote
Thats not a polo rad. Looks like a custom job.
adrian
http://jpsc.org.uk/forum/
jeffw
posted on 15/6/09 at 08:30 PM Reply With Quote
Cheapest option might be to get it re-cored ??
adithorp
posted on 15/6/09 at 08:45 PM Reply With Quote
You could just switch to a polo/VW rad. The commonly used Polo rads are...
1.1 polo rad 380x322
1.3 polo rad 430x322
SerckMarston part No's 2719517 (1.1) and 2719819 (1.3)
Those are both narrower than what you've got but there are wider ones in Golf's. They are the same layout though. I can check tommorow for a better fitting one.
adrian
jeffw
posted on 15/6/09 at 08:47 PM Reply With Quote
That sounds great....Do you know how they mount onto the car ?
adithorp
posted on 15/6/09 at 09:05 PM Reply With Quote
Each tank has 4 mounting boss' moulded on them 2 each side. Not very clear in this picture but you can just see one boss where the ally angle is mounting the fan to the rad'.
http://i189.photobucket.com/albums/z282/adrianthorp/Picture011.jpg
There's also 2 pegs on the bottom of the rad.
adrian
jeffw
posted on 16/6/09 at 05:25 AM Reply With Quote
So you have an adaptor plate which mounts the Polo rad to the Fury ? As you can see in the picture of my knackerd one it has two plates which bolt to the car on a mount.
posted on 16/6/09 at 08:27 AM Reply With Quote
definitely a nicely TIG welded custom aluminium rad.
have you tried to bend it bad ?
jeffw
posted on 16/6/09 at 08:43 AM Reply With Quote
It actually leaks from both sides...
adithorp
No, the polo 1.3 rad fitted the mounting plates on my chassis (just had to file one of the 4 holes). The ally' angle is just to mount the fan and is between the chassis mount and the rad on the same bolts.
Are your measurements the core size (thats what the makers list) or the overall size?
jeffw
posted on 16/6/09 at 08:44 AM Reply With Quote
Overall size. Looking at my wrecked one does the 1.3 Polo have the same mounting ?
adithorp
posted on 16/6/09 at 09:25 AM Reply With Quote
Not exactly but similar. It'd be easy to make an adapter. On the same face as yours it has 2 boss's on each tank.
adrian
jeffw
posted on 16/6/09 at 09:45 AM Reply With Quote
Looks like a plan then ....
matt_gsxr
posted on 18/6/09 at 04:31 PM Reply With Quote
hi there,
I only just noticed this post.
Here is a useful site for radiator pictures. You can see which one matches your dimensions and maybe even order from the site (as they are cheap).
Matt
p.s. good choice of car.
