Author: Subject: Supercharging bits
flak monkey
posted on 26/8/09 at 07:15 AM Reply With Quote
Supercharging bits
Long shot, but its worth a try.
Looking for some duratec bits:
Set forged pistons (either 9:1 or std 10:1 CR)
Set forged rods
Bypass valve (aftermarket copy of bosch type - like Forge 007p)
Small intercooler to fit inside the nose cone.
Sera
http://www.motosera.com
tomgregory2000
posted on 26/8/09 at 07:59 AM Reply With Quote
ive got an intercooler sat in the garage somewhere,
Can give it a measure if you want?
It came off a mk2 golf g60 and its quite a small thick one as it was fitted inside the engine bay rather than across the front of the car
tomgregory2000
posted on 26/8/09 at 08:02 AM Reply With Quote
here is a kinda pick of the intercooler
inbetween the plastic on the right
sucksqueezebangblow
posted on 26/8/09 at 09:28 AM Reply With Quote
Originally posted by flak monkey Small intercooler to fit inside the nose cone.
I've got a MKII Discovery intercooler in the shed. Might be a bit wide for your needs though. I'll measure it tonight.
[Edited on 26/8/09 by sucksqueezebangblow]
StrikerChris
posted on 26/8/09 at 11:41 AM Reply With Quote
I don't have one but slightly modded landrover defender intercooler fitted snuggly in my nosecone and there's plenty about 2nd hand in the 4x4 circles.
Gav
posted on 26/8/09 at 01:09 PM Reply With Quote
I think i have a spare bypass valve from my old Leon Cupra somewhere, its the bosch plastic one as i upgraded to a Forge unit, dont know if it would work or if i still have it but, if it would be of use i can look round in the garage for you.
flak monkey
posted on 26/8/09 at 01:25 PM Reply With Quote
Cool that might be useful, if only for testing
Thanks for the offers of intercoolers chaps. Will take some meaurments when I get a chance and will see what will fit
Sera
Gav
posted on 26/8/09 at 01:39 PM Reply With Quote
No worries i'm working away in the US atm but i'll have look in the garage when i get back and let you know.
posted on 26/8/09 at 03:07 PM Reply With Quote
Check out Saab BOVs. they're plastic but they're light and they're basically the same as the Forge units.
I think they're Saab 9000 turbos. Got mine on Ebay for a fiver...
Nice little recirculating BOV. Not so good for blowers with a CR but for Roots they're nice. For centrifugals a non-recirc is usually preferable...
Here's the Saab unit:
posted on 26/8/09 at 03:09 PM Reply With Quote
Looks like they're on quite a few Saab cars too....
Saab 900, 9000, GM 900, 9-3, 9-5
flak monkey
posted on 26/8/09 at 03:17 PM Reply With Quote
Thanks Ben
Mine will be a centrifugal SC so i could jsut vent to atmosphere i spose.
Why is there a difference?
Sera
posted on 26/8/09 at 04:28 PM Reply With Quote
It's all to do with the fact that Roots type blowers don't have compression ratios (they're constant displacement blowers) so if you put the blower output into the blower input (ie recirculate) you gain no extra heat and you save the energy required to suck air through the filter. And the air's already in the system for you to plant the throttle and ram it into the engine...
Blowers with a compression ratio meanwhile will recirculate the air getting hotter and hotter until you finally get back on the throttle just in time to dump a load of super heated air into the engine
So fixed displacement constant-CR blowers like Roots are best with recirc BOVs but other types (including turbos) usually do better with a non recirc BOV (though they're noisy so lots of OEM cars use re-circ valves to keep the noise down).....
At least that's my recollection of Corky Bells wonderful book on the subject
