Author: Subject: BERU Plug leads for XE
westy turbo
posted on 15/10/09 at 05:24 AM Reply With Quote
As above for coil pack in good condition
mediabloke
posted on 15/10/09 at 11:24 AM Reply With Quote
Sorry if it's a daft question, as I guess it depends on which coil pack, but are the posts not the same as the Vx? I spent ages looking around for a set of leads to fit my early Ford coil pack onto my Vx plugs, until I swapped it for a later Ford one with the correct post sizes.
Francis
blakep82
posted on 15/10/09 at 11:59 AM Reply With Quote
yep later ford coil pack works fine with standard vauxhall leads
________________________
westy turbo
posted on 15/10/09 at 02:10 PM Reply With Quote
Thats the one and your right it like a focus one
mediabloke
posted on 16/10/09 at 09:38 PM Reply With Quote
Yep - the insulators look the same size, but it depends on the pin sizes themselves. Got any photos of them?
westy turbo
posted on 17/10/09 at 08:04 AM Reply With Quote
from the cables? or the coil?
mediabloke
posted on 17/10/09 at 02:03 PM Reply With Quote
Yep - I meant the ones on the coil. The connectors on the coil end of std XE leads will fit a coil with conductors about 3-4mm wide. It's then just a case of getting a std set from Vauxhall (seem to be better than some aftermarket ones).
