Author: Subject: electronic ignition
david
posted on 22/2/10 at 11:45 PM Reply With Quote
electronic ignition
anyone out there selling an electronic ign. setup.It is for a series 1 landrover, but I am sure others could be adapted
snapper
posted on 23/2/10 at 05:19 AM Reply With Quote
Megajolt will be the cheapest.
Autosportslabs.com has all the details nof how to build and install and i belive there is a guy on the site who has fitted one and has a map for a series 1 landy
I eat to survive
I drink to forget
minitici
posted on 23/2/10 at 10:38 AM Reply With Quote
If you are needing a positive earth electronic ignition then have a look at the Aldon (Pertronix) Ignitor system.
It fits inside the dizzy.
I've used them on several of my Mini engines.
Aldon
Pertronix
wilkingj
posted on 23/2/10 at 12:02 PM Reply With Quote
I am NOT 100% sure, but I am sure I remember the lads on the UK-LRO mailing list using the electronic Dizzy of a Metro or similar.
Evidently is a good substitute.
You need to check this out if you persue that line.
Either that or put on a Megajolt.
EDIT:
As for the Positive Earth Electrics, I would convert to Neg Earth. Easy if you have a dynamo.
It depends on how original you want to be. but them electronic ignition isnt very original either
[Edited on 23/2/2010 by wilkingj]
Best Regards
Geoff
http://www.v8viento.co.uk
mad4x4
posted on 23/2/10 at 12:58 PM Reply With Quote
I have a megajolt that will probably be up for grabs end of march as I am going to megasquirt
Scot's do it better in Kilts.
