Wheels244
| posted on 25/1/12 at 09:10 PM |
WTD: Steel Tank\cylinder
Hello All
I need a steel tank or cylinder for the hydraulic tank for the log splitter that I'm building.
I could ( and might have to ) make one but it will speed things up a bit if anyone has got one lying around.
It needs to be at least 30 litres capacity, doesn't need to be any bigger.
An old air receiver from a compressor would do or something like.
Has anybody got anything ?
Rob
big_wasa
| posted on 25/1/12 at 09:20 PM |
Small gas cylinder as found in the bottom of many hedge rows
T66
| posted on 25/1/12 at 09:24 PM |
http://www.mig-welding.co.uk/forum/showthread.php?t=30880
Wheels244
| posted on 25/1/12 at 09:28 PM |
I did think about a gas cylinder - bit wary of blowing myself to kingdom come though
Wheels244
| posted on 25/1/12 at 09:30 PM |
Thanks - but it won't let me view as I'm not a member.
owelly
| posted on 25/1/12 at 09:31 PM |
I have a gas cylinder you can have WHEN YOU COME AND COLLECT THE OTHER STUFF!! Sorry, was I shouting?
http://www.ppcmag.co.uk
Wheels244
| posted on 25/1/12 at 09:37 PM |
Sorry Owelly - I haven't forgotten - been really busy with work - it does get in the way!
I WILL make it over in the next couple of weeks
I don't suppose the gas cylinder is purged and perfectly safe for me to weld
[Edited on 25/1/12 by Wheels244]
owelly
| posted on 25/1/12 at 09:49 PM |
When you say purged and ready to weld, does that mean half full of gas? I'll soon knock the piller valve off and fill it with water......
T66
| posted on 26/1/12 at 05:51 AM |
The link is a stack of free gas cylinders in Cheshire....
luke
| posted on 26/1/12 at 08:50 AM |
I have an empty BOC CO2 cylinder if you want it. I cant get rid of it and BOC wanted to charge me to take it back as i'm not a customer.
Unsure of capacity but it stands up to about hip height and is about 6 inches diameter.
Yours if you want it.
Luke
hughpinder
| posted on 26/1/12 at 09:17 AM |
Does it need to be pressure rated, if not, you can buy your hydraulic fluid in a 25l steel drum, if that big enough ....
Regards
Hugh
| posted on 26/1/12 at 10:28 AM |
If you don't want that large a tank Go to a garage that does air con and ask it they have an empty cylinder. They are disposable and a nice
small size.
Wheels244
| posted on 26/1/12 at 08:49 PM |
Luke
Sorry Luke it would be too small. A pub might take it off you, it sounds like a pub bottle.
Thanks anyway.
Wheels244
| posted on 26/1/12 at 08:51 PM |
Regards
Hugh
Thanks Hugh - I've bought the oil, it came in a plastic container.
I think an oil drum would be too thin for me to weld the ancillaries to.
Wheels244
| posted on 26/1/12 at 08:52 PM |
small size.
Thanks Pete, any idea of the capacity of them ? Needs to be 30litres.
