AndyW
| posted on 2/9/12 at 05:41 PM |
air temp sensor mondeo mk2 1997?? Long shot....
Hi all,
i know its a long shot but before I trawl e-bay, anyone happen to have an air temperature sensor for a 2.0 blacktop 1997ish, my loom is from a
mondeo??
please let me know if you have anything....
big_wasa
| posted on 2/9/12 at 05:55 PM |
Plastic or metal Maf ?
AndyW
| posted on 2/9/12 at 05:57 PM |
metal. Had a fault code saying air temp sensor voltage
Is the air temp sensor in the maf?
big_wasa
| posted on 2/9/12 at 06:12 PM |
On the plastic one yes, metal one no. Its a push fit in the bottom of the rubber tube.
I have a spare you can have, I will upload a photo.
have you got one conected ? how have you wired it ?
[Edited on 2/9/12 by big_wasa]
AndyW
| posted on 2/9/12 at 06:23 PM |
Thats the thing Warren, not got one connected, just a spare plug on the loom. Runs ok, a bit rich i think. I have a threaded hole on the inlet plenham
which I think the factory use for the emerald injection temp sender.
Its the only thing missing from the system.
AndyW
| posted on 2/9/12 at 06:24 PM |
That looks like the one! Just now wondering how Im going to fit it into a threaded hole!!!
U2U me and I will send you some beer tokens for it!!
thanks
perksy
| posted on 2/9/12 at 06:36 PM |
If you want to you can test them with a Hairdryer, just connect up an voltmeter to the sensor in ohms scale and watch for the difference in continuity
as the sensor heats up and then cools down again
Also you can check the ref'(5 volt supply) voltage from the ECU using the voltmeter
big_wasa
| posted on 2/9/12 at 06:40 PM |
On mine I spun the sensor in the lathe and very carfully self taped it into the boss in the mani. Failing that scope it with a meter and match it to
one that will fit.
It will run VERY rich with out as I think it defaults to minus 40 deg. I know with some throttle body set ups people just tape it up under the mani. I
doubt there is much differance in tempreture.
Just pm me your address again, I have a few bits to post one day this week.
Oh and whats in the boss at the moment ? It wont like air leaks.
AndyW
| posted on 2/9/12 at 06:44 PM |
In the boss is a bolt so no air leaks, and your right the fault code reader showed air inlet temp as minus 40
I will pm address
Thanks Warren
baz-R
| posted on 3/9/12 at 04:35 AM |
Early zetec's had a screw in IAT sensor have a look around 93 models with aloy inlets
If you get stuck u2u me and I will try and get a pt no. Of one if mine don't think plug is the same mind!
big_wasa
| posted on 3/9/12 at 06:15 AM |
Yeh its a big thread, 3/8 from memory. what thread is the boss in your mani ?
AndyW
| posted on 3/9/12 at 07:48 AM |
I will check the thread today and let you know.
