Author: Subject: WTD : "Sausage" Style Air Filter (Pipercross)
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 8/10/12 at 08:39 PM Reply With Quote
I'm after a "sausage" style air filter for an R1 BEC.
I don't have the room under the bonnet for the original R1 airbox, so I need something a little smaller in height.
I've got about 3" of clearance between the intake and the underside of the bonnet.
I've seen pipercross ones which other people tend to use - they're just a bit expensive.
I've got a 2003 R1 5PW engine and I can fabricate a new intake plate if the holes aren't spot on.
Anyone got anything?
chicade
posted on 8/10/12 at 09:01 PM Reply With Quote
Standard air box will fit turn it 180* and you will have to cut the bottom slightly to clear engine cradle and extend intake temp sensor wiring I have done it on my r1 Indy and fits under standard bonnet fine
chicade
posted on 8/10/12 at 09:07 PM Reply With Quote
Or if ya def want a sausage filter look at this on eBay item number 261110216851
DavidW
posted on 9/10/12 at 06:32 AM Reply With Quote
When I needed one and failed to find second hand I found the cheapest place was GBS.
[Edited on 9/10/12 by DavidW]
Barkalarr
Contributor
Posts 945
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 9/10/12 at 06:56 AM Reply With Quote
Thanks guys - chicade, can you take a picture of your air box please. Someone else on here said exactly the same thing, but it just doesn't look like it will fit - and thanks for the link.
FASTdan
posted on 9/10/12 at 07:26 AM Reply With Quote
I have a 'square' style pipercross PX600 in stock that was a return (its still unopened) that should be under 3" I think. I could do this and a blank baseplate for £60 posted. I also have R1 specific baseplates in stock (for R1 carb models) - this plus filter £75 posted.
U2U if you want any of the above.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
