Author: Subject: WTD: Some tube with a nut welded on the end
pekwah1
posted on 5/2/13 at 11:24 AM Reply With Quote
Hi Guys,
Bit of a long shot as i don't have a welder...
I need 2 lengths of tube with a nut welded on the end.
The tube would need to be 20mm internal diameter and around 8 inches and just needs a thread on one end, as big as a nut as you can fit which i think is about an m12.
Again, after 2 of these.
If anyone can help, please let me know!
Regards,
mcerd1
posted on 5/2/13 at 01:23 PM Reply With Quote
whats it for ?
(maybe we could suggest some altenative ways of making it....)
NigeEss
posted on 5/2/13 at 01:55 PM Reply With Quote
What wall thickness and how critical is the id? I've got bit of galved conduit 20mm id, 2mm wall.
pekwah1
posted on 5/2/13 at 02:07 PM Reply With Quote
Material and thickness doesnt really matter.
It's to essentially put the front indicators on stalks so that they protrude far enough to be seen from all angles by mr. IVA.
As long as they aren't made out of plastic then should be ok!
trextr7monkey
posted on 5/2/13 at 05:26 PM Reply With Quote
we onlyhave thick wall tube that size which would really slow your car down
there is however some 1" ali bar that could be bored / tapped- presumably it is hollow for wires to thread through?
atb
Mike
loggyboy
posted on 5/2/13 at 05:31 PM Reply With Quote
I plan on using an old lamp support:
http://www.argos.co.uk/static/Product/partNumber/4308021.htm
http://www.argos.co.uk/static/Product/partNumber/9061882.htm
they are pre threaded, hollow, stainless and avialable at most tips (allthough I got mine from the house when they were ready to be thrown out)
Mistral Motorsport
SteveWallace
posted on 5/2/13 at 06:01 PM Reply With Quote
This is how I did mine...
15mm copper tube with an M8 nut knocked into each end and glued in place (could be soldered I guess). The bike indicator had a hollow M8 bolt with the wires going through it and I drilled a hole through another M8 set screw for the end that fits to the nose cone so that the wires could go through that as well. This was secured to the nose through an M8 hole and a couple of large diameter penny washers to spread the load. The two sections of black tape are just to get the right diameter for a cosmetic bit of plastic sleeve (a couple of £ from B&Q), sprayed to match, to tightly fit over the top. The blue plastic nut in the second picture is cosmetic only and is a plastic pumbing nut. It may have to come back off to meet IVA radius requirements.
