rucksak
| posted on 9/9/13 at 08:52 PM |
X/Flow Starter Motor
Hi, I have a 2.0 Pinto Engine with a X/Flow Gearbox, i am after a starter motor to fit, the stater i need is a 3 bolt fixing, sits on the passenger
side of the car.
Or does anyone know any part numbers that may help me, i got 2 so far from my local spare shop which i have had to return as both that were listed for
a 1977 mk2 escort ended up with the starter solinoid upside down.
britishtrident
| posted on 10/9/13 at 11:37 AM |
side of the car.
Upside down is fine as long as it fits.
[/I]
Not Anumber
| posted on 10/9/13 at 02:41 PM |
Are you using the Pinto flywheel or the crossflow flywheel ?
rucksak
| posted on 10/9/13 at 07:58 PM |
Hi, using a X/flow flywheel, thought about using one upside down but the car will be a bit low to the road.
britishtrident
| posted on 10/9/13 at 08:36 PM |
You need to know is the flywheel is for an inertia starter or a pre-engage starter or is is the universal type that works with either. The
difference lies in which side off the ring gear has a chamfered lead in for the starters drive gear.
2 litre Pintos all used a a pre-engage starter, early 1600 Pintos used an inertia starter and most but not all xflos used an inertia starter.
[/I]
Bhpmad
| posted on 13/9/13 at 09:35 AM |
Lrs00110 is the lucus part very hard to get as most people supply lrs00168 but I do know a place in Sutton in Ashfield
